DKIM and SPF settings
I am trying to follow the settings for dkim and spf as detailed in the knowledgebase.
Entering any settings and clicking save results in the entries not being saved and the web admin page does not load.
Has something broken? I followed the same guide previously without any issues
I forgot to add, it is a fresh vps install of debian12.
No other software added.
are DKIM and SPF set on DNS?
the button “save” will be enabled when all the params are setted!!
Yes, DNS is set up, I will try a different distribution.
Thanks for your reply
After a little sleep, I looked at this again, turns out one of my dns providers’ settings was wrong. Changed this to what it should be and hurrah! all is good.
It’s a really good aio mail system…
I took a while to configure everything, including a misadventure with a successful hack on SMTP, but FINALLY everything works fine, something still need to be fixed (clamav and few errors with SSL).
We all need a little bit of assistance here in community… Axigen can be the top for Debian!
