Running Axigen Webmail in an HTML Frame or IFRAME
In earlier versions of Axigen, I could run webmail inside an HTML frame. I think now however that X Header security is now enabled. Can you please advise how to make this work again? I dont think its a code issue its a webserver configuration issue.
As you have found the old and obsolete model of “serving” the Axigen WebMail interface via an HTML frame is not supported anymore and this is why my advice is to find another solution for your problem (most probably you like to serve the WebMail interface on the same URL with your website).
