Hi All,
Good day!
I’m using axigen-10.3.1-1.x86_64 on CentOS 7.7
I’m trying to configure Gmail to use my Axigen account for sending out some emails.
In Axigen, I created a LetsEncrypt SSL cert and I have configured the SSL settings for the SMTP Receiving service to use the new SSL cert.
Now when I try to configure Gmail to use my Axigen server, it shows this error message:
“TLS Negotiation failed, the certificate doesn’t match the host., code: 0”
I’ve already tried to:
. tick all the options in the “Allow the following SSL versions” under SSL SETTINGS.
. use SSL with port 465
. use TLS with port 465
. use SSL with port 587
. use TLS with port 587
I already checked that:
. the server’s hostname matches the name of the SSL cert
. the user’s domain matches the domain of the hostname and the SSL cert
And this is what I see in the Axigen logs:
2020-07-26 18:35:56 +0800 16 mail SMTP-IN:00000000: << SSL: client hello, remote 209.85.221.47:38262, version TLS 1.3 (0304)
2020-07-26 18:35:56 +0800 16 mail SMTP-IN:00000000: << SSL: client hello, remote 209.85.221.47:38262, session id 6cbef0f6e189223b39bb323ae82c205f845e5114e8838b50366aa93445965f33
2020-07-26 18:35:56 +0800 16 mail SMTP-IN:00000000: << SSL: client hello, remote 209.85.221.47:38262, 19 cipher suites: aaaa130113021303c02bc02fcca9cca8c02cc030c009c013c00ac014009c009d002f0035000a
2020-07-26 18:35:56 +0800 16 mail SMTP-IN:00000000: << SSL: client hello, remote 209.85.221.47:38262, sni extension for mail.this_is_the_domain.com
2020-07-26 18:35:56 +0800 16 mail SMTP-IN:00000000: >> SSL: server hello, remote 209.85.221.47:38262, version TLS 1.3 (0304)
2020-07-26 18:35:56 +0800 16 mail SMTP-IN:00000000: >> SSL: server hello, remote 209.85.221.47:38262, session id 6cbef0f6e189223b39bb323ae82c205f845e5114e8838b50366aa93445965f33
2020-07-26 18:35:56 +0800 16 mail SMTP-IN:00000000: >> SSL: server hello, remote 209.85.221.47:38262, cipher suite 1302
2020-07-26 18:35:56 +0800 16 mail SMTP-IN:00000000: >> SSL: server write cert, remote 209.85.221.47:38262, version TLS 1.3 (0304)
2020-07-26 18:35:56 +0800 16 mail SMTP-IN:00000000: previous line is repeated 1 time.
2020-07-26 18:35:56 +0800 16 mail SMTP-IN:00000000: >> SSL: server write cert, remote 209.85.221.47:38262, certificate 1: serial 0361E59EF4DC54B28108F2AF2DE905C85057
2020-07-26 18:35:56 +0800 08 mail SMTP-IN:00211FE7: [a.b.c.d:465] connection accepted from [209.85.221.47:38262]
2020-07-26 18:35:56 +0800 16 mail SMTP-IN:00211FE7: >> 220 mail.this_is_the_domain.com Axigen ESMTP ready
2020-07-26 18:35:57 +0800 16 mail SMTP-IN:00211FE7: << EHLO mail-wr1-f47.google.com
2020-07-26 18:35:57 +0800 08 mail SMTP-IN:00211FE7: Greylist disabled
2020-07-26 18:35:57 +0800 08 mail SMTP-IN:00211FE7: Set max data size to 30720 KB
2020-07-26 18:35:57 +0800 08 mail SMTP-IN:00211FE7: Set max received headers to 30
2020-07-26 18:35:57 +0800 08 mail SMTP-IN:00211FE7: Maximum recipient count set to 1000
2020-07-26 18:35:57 +0800 08 mail SMTP-IN:00211FE7: Wait for processing response at least 10 seconds
2020-07-26 18:35:57 +0800 08 mail SMTP-IN:00211FE7: STARTTLS extension allowed
2020-07-26 18:35:57 +0800 08 mail SMTP-IN:00211FE7: 8BIT MIME accepted
2020-07-26 18:35:57 +0800 08 mail SMTP-IN:00211FE7: BINARY DATA extension allowed
2020-07-26 18:35:57 +0800 08 mail SMTP-IN:00211FE7: PIPELINING extension allowed
2020-07-26 18:35:57 +0800 08 mail SMTP-IN:00211FE7: DSN extension denied
2020-07-26 18:35:57 +0800 08 mail SMTP-IN:00211FE7: Set local delivery to all
2020-07-26 18:35:57 +0800 08 mail SMTP-IN:00211FE7: Set remote delivery to auth
2020-07-26 18:35:57 +0800 16 mail SMTP-IN:00211FE7: >> 250-mail.this_is_the_domain.com Axigen ESMTP hello
2020-07-26 18:35:57 +0800 16 mail SMTP-IN:00211FE7: >> 250-PIPELINING
2020-07-26 18:35:57 +0800 16 mail SMTP-IN:00211FE7: >> 250-AUTH PLAIN LOGIN CRAM-MD5 DIGEST-MD5 GSSAPI
2020-07-26 18:35:57 +0800 16 mail SMTP-IN:00211FE7: >> 250-AUTH=PLAIN LOGIN CRAM-MD5 DIGEST-MD5 GSSAPI
2020-07-26 18:35:57 +0800 16 mail SMTP-IN:00211FE7: >> 250-8BITMIME
2020-07-26 18:35:57 +0800 16 mail SMTP-IN:00211FE7: >> 250-BINARYMIME
2020-07-26 18:35:57 +0800 16 mail SMTP-IN:00211FE7: >> 250-CHUNKING
2020-07-26 18:35:57 +0800 16 mail SMTP-IN:00211FE7: >> 250-SIZE 31457280
2020-07-26 18:35:57 +0800 16 mail SMTP-IN:00211FE7: >> 250-HELP
2020-07-26 18:35:57 +0800 16 mail SMTP-IN:00211FE7: >> 250 OK
2020-07-26 18:35:57 +0800 16 mail SMTP-IN:00211FE7: >> 421 mail.this_is_the_domain.com error reading data
2020-07-26 18:35:57 +0800 08 mail SMTP-IN:00211FE7: closing session from [209.85.221.47]
2020-07-26 18:36:00 +0800 02 mail SERVER:00000000: previous line is repeated 1 time.
2020-07-26 18:36:00 +0800 02 mail SERVER:00000000: SSL_accept error (Success)
Any suggestions would be greatly appreciated.
Thank you very much.
